Easy 2m TX - coils and transformers winding details - zener voltage
Re: Easy 2m TX - coils and transformers winding details - zener voltage
Post by Admin on Sat May 17, 2014 10:52 am
Ok Jim,
I can tell you that the VHF coils (L2, L3, T2 & T3) were about 6mm Dia. self supporting, and the wire gauge was about 0.5mm Dia. L1 was just "thin" wire robbed from a relay. The 10.7MHz IF can was ready wound.
Post by Jim McLucas on Fri May 16, 2014 11:30 pm
Thanks for the zener diode info.  I saw the box with the coil turns, but I need to know the coil diameter, coil length, and wire size in order to wind the coils. If you don't have this info, then I will calculate the inductance from the given capacitor values, and then use an inductance calculator to determine the missing info.
Thanks,  Jim
Jim McLucas
Post by Admin on Thu May 15, 2014 5:46 pm
If you look at the drawing:
You will see that to the right of T3 there is a little box (above here) where the coil details are given.
The zener diode I forgot to include but that is only about 5.6v, 6.8v or so. I had a lot of 6.8v zeners at the time, but I always prefered 5.6 because that value has a +/-0 degrees temperature coefficient.
Post by jwmc@ieee.org on Wed May 14, 2014 10:10 pm
For the Easy 2m TX, it would be helpful to have winding details for L1, L2, and L3.  Also for T1, T2, and T3.  Coil diameter and wire size, (and perhaps inductance, if known). Also the voltage of the zener diode which regulates the voltage for D1 and D2 and the 150k resistor.
I can determine these things myself, but it would save time if you can supply this information, if you have it available.
Thanks,  Jim
jwmc@ieee.org
