HF VFO coil data needed
Re: HF VFO coil data needed
Hi mas,
I am sorry, I cannot find a project named "(THE) HF VFO" on sm0vpo.com. Please try to find the source.
Ivan- Posts : 772
Hello harry,
I'm building your THE HF VFO for a small project, I found it somewhere on your site. (sorry I can't post the link to the site)
I'm only missing the information for the coils, diameter, length thickness off the wire, only the amount of turns is just not enough.
With the proper data I can wind the coil myself, or calculate an aternative one, After I calculate how much uH the coil has, I could even use a alternative diameter and amount off windings.
Thanks and Greets mas
mas- Guest
» usb 2 serial data
» Welcome arb-92
» Vertical Load Coil
» Coil formers, PCB mount 4pcs US$1 (20pcs / lot)
» 455kHz IF cans + MW oscillator coil - component source
» Welcome arb-92
