Cascade/Cascode IF Amplifier question
Re: Cascade/Cascode IF Amplifier question
Post by Admin on Sat Dec 15, 2012 10:06 pm
This circuit has many advantages. The most eminent is that the current is re-used - ecconomy. In spute of that it also has a very high gain and is extremely stable.
For me it is also that it uses no coils, other then the input filter.
(no text given)
Post by roger_ on Fri Dec 14, 2012 11:39 pm
Thanks Harry. What's the primary advance to this design (if not stability)?
roger_
Post by Admin on Thu Dec 13, 2012 9:58 pm
Hi Roger. I found the amplifier to be VERY stable if you did not use any wound components at the output. I used a regulated supply anyway.
Give it a try and see what you think. I did not try to miniaturise it because I was conscious of input/output coupling. I also used good quality caps for decoupling, but it was not a major consideration when I built that stage.
(no text given)
Post by roger_ on Thu Dec 13, 2012 2:10 am
Regarding this circuit: sm0vpo.com/blocks/cascade-cascode_amplifier_01.htm
Is the isolation between the transistors better than when typical CE amplifiers are cascaded? In the past proper power supply decoupling has been a problem for me in high gain (50+ dB) IF amplifiers, and I'm wondering if this circuit is more stable.
Thanks!
roger_
