Power filter choke?
Power filter choke? Empty Re: Power filter choke?
Post by Admin on Sun Sep 17, 2017 9:47 pm
Hi Graham,
As Ivan says, that's a good idea.
Rather clever, in fact. These inductors are very common in most rubbish dumps and builders skips.
Thanks for the tip. BR Harry - EA/SM0VPO
Post by Ivan on Sat Sep 16, 2017 2:27 pm
that's a good idea! Moreover, chokes can be connected into series so that their inductance adds.
Power filter choke? Empty Power filter choke?
Post by GrahamH on Sat Sep 16, 2017 1:24 pm
I recently acquired/scrounged two old 2*20W fluoro light fittings. By connecting a capacitor across the ballast and applying a variable frequency AF osc to find resonance I have calculated and inductance of around 3 1/2 Henrys. These may have application for filtering in valve power supplies. A low value for this purpose admittedly, but at only the cost of stripping the light fitting, a better result than using a resistor.
GrahamH
» Raven
