usb 2 serial data
Re: usb 2 serial data
So gIad you got it working but I did not have much to offer.
Interesting URL. Couldn't AliExpress have given you a longer one ? I thought some of the internal URLs at work were a bit long but this one is a bit extreme. Good job no-one had to read it over the phone
Best regards Harry - SM0VPO
Thank you all for your comments. i got some modules from aliexpress.com for $2.60 each.
https://www.aliexpress.com/item/FTDI-FT232r-Basic-Breakout-USB-TTL-3-3v-5v-Pro-Mini-MWC/32782799434.html?spm=2114.search0104.3.60.Ze7sfG&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10307_10615_10301_10303_10142,searchweb201603_6,ppcSwitch_5&algo_expid=08ec3d3c-c825-4b5a-95b1-986d0befbf4b-8&algo_pvid=08ec3d3c-c825-4b5a-95b1-986d0befbf4b&transAbTest=ae803_4&priceBeautifyAB=0
they are made for the arduino but when i connected 2 of them with txd->rxd and rxd->txd it worked grate. i got my usb to serial to usb working fine.
you guys are grate. you pointed me in the right direction. i never thought to google a usbuart. thank you ivan paul and harry.
happy new year to you all - bit late but didnt get the chance to tell you all.
Densil- Posts : 47
I think that RS232 is a bit too slow for many applications. USB2 has a data rate of something like 480Mb/s.
Can the handshaking pins work that fast? It would be interesting to see how fast they will work.
But I think that Densils original problem was to convert USB data and keep the data rate, at least that is how I interpreted the original post.
Perhaps Densil coiuld clarify a bit more?
USB to rs232
I believe you can use the RTS/DSR signals for switching if you don't need them for flow control. I have used the cheap FTDI modules with PIC micro controllers and find them easy to use. I like the versions with a mini USB socket on board as they are self powered. I use TeraTerm as a terminal program since hyper terminal disappeared after win XP.
JCTTY- Guest
Hi Densil, Ivan and Paul,
Strange, I didn't get any email notification about this thread!! Hafta check my config. Sorry for the delay Densil.
It was interesting about the Onion Omega 2, and USB to TTL 3.3V 5.5V Serial Adapter Module. The latter only costs just US$1.5 from Aliexpress. Looks like these will do what you are asking.
You may want to take a look at the FT232R chip. Here is the datasheet:
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
Pages 23 and 24 will be of interest.
One of the above modules are based on this chip (FT232RL), but it depends on how deep you want to go. The modules are the quickest and easiest way to go.
I had a Swedish Christmas party yesterday and a course the day before so I have been offline for a bit. Have another company Christmas party tomorrow night. It's "all go!!" :-)
@Densil, please let us know how you get on with this project as I would be interested to know how succesful you are. I would also be interested in knowing if the modules can switch DC to the end equipment - i.e. can you unplug one end and the 5V out at the other end stops? I ask because I can also see another use. At work we have a USB DC switch to power-down 32 LTE broadband dongles, and the switch just cuts the +5V on the USB cables to disable the LTE modem.
Onion Omega 2 is another solution, with more capabilities.
Ivan- Posts : 788
usb 2 serial data
hi Harry
I have 2 wideband oscillator / transmitter modules which can be modulated up to 600mhz and a matching rx modules. the rf frequency is about 10ghz.
I want to put a usb signal through the 2 module pairs. I thought the 2 usb data pins was tx/rx but it is not. bothe usb data pins are bidirectional and change to hiZ on rx and loZ on tx.
Is there any way i can convert the usb data to separate tx and rx ?
I have got two pairs of modules so i can have 2 way data links but i need to get txdata and rxdata separated. The modules works to sent tv and even the tx from my 2m and 70cm radios.
Got any ideas ? or is this off topic on this forum. Not in a hurry cos this is a winter project.
Have u got back from spain yet ? i tried listening 4u on 14mhz but did not hear you. just so as you know i tried.
Thanks in advance
Thanks in advance
Densil- Posts : 47
