Pierce-gate quartz oscillator worksheet
Doh! Rookie mistake... Of course, in a shunt case like RB, no resistor means RB = infinity (by oppostion to a series case like RS, where no resistor means RS = 0 Ω, or a link...). Outside math, the concept of infinity being of no use to us, the sentence should simply read:
" In the case of microcontroller or ASIC ICs, RB may be redundant as it is already embedded in the IC: RB should then be left out."
Thank you, Ivan, for picking it up!
ARB
ARB
arb-92- Posts : 4
Re: Pierce-gate quartz oscillator worksheet
Hi Arb,
thank you for your effort and kind giving its results for free use. I have one small correction only. You wrote
" In the case of microcontroller or ASIC ICs, RB may be redundant as it is already embedded in the IC.
Then, RB = 0 Ω."
This would short the input and output of the gate. IMHO RB must be infinity in this case (i.e. no external resistor is needed).
Then, RB = 0 Ω."
Ivan- Posts : 788
Hello,
For your perusal, please find herewith a link to an Excel spreadsheet giving preliminary design values for the passive components associated with a Pierce-gate quartz oscillator, today the prevailing clocking circuit for digital ICs.
The complexity of the non-linear dynamics at stake usually makes an iterative (trial and error...) process almost mandatory for more advanced optimization, but hopefully those design values are a good starting (working) point.
http://213.114.131.21/draw/pierce-gate-osc-calc.xls
Also given herewith is a link to a work document explaining the logic behind those design values (hopefully...), and is sampled from my reading notes while researching the subject.
http://213.114.131.21/draw/quartz-ii.doc
Feel free to use the worksheet, provide comments and eventually suggest corrections when warranted. Thanks!
Best,
ARB
Best,
ARB
arb-92- Posts : 4
» Welcome arb-92
» How to determine LDMOS Gate and Drain Leg Ohm and Impedances
» 455KHz IF oscillator with only three parts
» Oscillator experiments continued
» Crystals / oscillator modules
