PLL Tx loop filter question
PLL Tx loop filter question Empty Re: PLL Tx loop filter question
Post by Admin on Sat Jun 16, 2018 7:37 pm
Hi Joy,
It should be ok as it is.
The filter time-constant is to be long enough to prevent the lower modulating frequencies from being seen as a frequency error.
It matters not what the reference frequency is, but it does matter what divide rate you use. If your lowest modulating frequency is 20Hz, and you select the filter to have a knee at about 10Hz, 100mS. All is well, but it will take a long tie for the loop to lock.
If your total divide rate is in the region of 100 then your loop filter time constant can be 1mS. In this event then the loop filter can be a lot longer since it will still achieve lock very fast.
Post by joy444444 on Mon Jun 11, 2018 7:21 pm
PLL Tx loop filter question Img-2010
One last question Harry. This is the loop filter from your FMTX kit. The time constant is 220 milliseconds (22k and 10uf). Does the reference frequency matter? This loop filter worked fine with reference frequencies of 300 KHz to 800 KHz and audio sounded good when I was testing it in 2015. Can the same values for loop filter be used if the reference frequency is 25 KHz or something else? Does it make any difference in the audio quality?
Thanks
Joy
joy444444
Post by Admin on Fri Jun 01, 2018 10:16 pm
Thank you, praise indeed.
The only problem with experience is that you have to be old to get it Crying or Very sad
But the reason I am still working at (almost) 67 is that I have a lifetime of experience to pass on to the newer engineers and technicians we have a work.
Post by joy444444 on Thu May 31, 2018 8:20 pm
You are one of my gurus. Most of what I know about RF circuits I've learned from you.
joy444444
Post by Admin on Thu May 31, 2018 8:03 pm
Hi Joy,
Then I am really pleased that I was of some assistance.
This 67 year-old brain has a few defects, but it seems that I can remember distant facts and theories quite well, and even apply them. However, remembering why I went into a room is sometimes a challenge ;-)
Last edited by Admin on Thu May 31, 2018 8:04 pm; edited 1 time in total (Reason for editing : tipping errorz)
Post by joy444444 on Wed May 30, 2018 11:47 pm
Yes Harry you explained it well, and thank you for taking out the time. Actually I have the pdf copy of the kit. I designed a PLL FM transmitter for 96 MHz and used your values for the loop filter and it worked great with 750 KHz ref frequency. Google WBFM kit for your circuit it shows up at the top. Attaching my circuit using your loop filter values. PLL Tx loop filter question 3-410
joy444444
Post by Admin on Wed May 30, 2018 10:17 pm
http://213.114.131.21/conv/syn-info.htm#loop
Hi again Joy,
Just spent 20 minutes composing a reply to you, then accidentally erased everything. Anyway, the above link should explain everything you need to know about the loop filter design.
You are using 102MHz, so I guess you are making an FM transmitter. You therefore need to make your loop filter to have a rolloff frequency at about 15Hz (lower than the lowest modulating frequency). You also have a ÷256 prescaler, and frequency dividers are also filters. This means your loop filter time-constant should cut in at 15Hz x 256 = 3840Hz = 0.26mS (can be a little longer).
There is a compromise:
 - CR = long enough so that it does not see modulation as an error
 - CR = short enough to allow a practical loop lock time
In your case, 500mS lock time is not a problem, assuming you are building a broadcast station. If you wanted to change rapidly between TX and RX then it would be a problem.
Another point, a synthesiser is an amplifier and two integrators in a closed loop. That is the definition of a multivibrator. It can occur that your loop is constantly "hunting", that is overshooting the correct frequency and in fact oscillating. The cure for that is putting a damping resistor in series with the capacitor in your first CR time-constant.
Another problem is "synthesiser whine". That is hearing the reference frequency on the modulation. If your reference frequency is, say 300kHz then you can add an extra CR circuit (or 2) to hard filter (without damping) with a cut-in frequency of about 200kHz or more. With a high reference frequency this is not normally a problem.
You may want to take a look at a practical example. See http://213.114.131.21/conv/4040_divider_02.htm
I once designed a WBFM synthesiser circuit for a kit company, but they never paid me. Perhaps I can dig out the circuits and PCB, then post them here for you? Leave that with me - I will search, but no promises.
Have I explained this in an understandable way? Have I answered your question?
BR Harry - (EA/)SM0VPO
Last edited by Admin on Wed May 30, 2018 10:23 pm; edited 1 time in total (Reason for editing : 67-year old brain cannot tell the difference between singulars and a plural - brain failure - correctin !!)
Post by joy444444 on Wed May 30, 2018 8:12 pm
PLL Tx loop filter question 15fbde10
I have run into problem in the past when working with 400 khz ref frequency with the values of R1-R4 and C1-C2. What value should I try? Make it 375 KHz with 12MHz xtal and /32 from CD4060. Your experience will help me out here.
joy444444
Post by Admin on Tue May 29, 2018 10:48 pm
My e-mail addresses (all valid) are:
harry.lythall@sm0vpo.com  (the "normal" one)
harold.lythall@sm0vpo.com  (the posh-official one, job hunting, etc)
hotmail@sm0vpo.com  (genuine. Spammers usually "correct" it ;-)
british.inteligence.sweden@sm0vpo.com  (I use this for newsgroups. SPAMmers never reply ;-)
   (note the defective spelling - deliberate ;-)
PS - Yes you can post schematics. If it's on the web then click "Insert Image" and paste in the URL.
PLL Tx loop filter question Empty PLL Tx loop filter question
Post by joy444444 on Sat May 26, 2018 4:49 pm
I can't post the schematic here. What's your email Harry?
With a reference frequency of 400 KHz, what should the values of R1-R4, C1 and C2 be?
Thanks in advance for your reply Harry.
Joy
joy444444
