20M Loop
20M Loop Empty Re: 20M Loop
Post by Admin on Sat Feb 02, 2019 5:33 pm
zsolt wrote:HI,
is the talking done here about 20 meter loop antenna ? really 20m in diameter in vertical position ?
20-metre (wavelength) amateur radio band = 14.000 MHz to 14.350 MHz.
Post by Scheig on Thu Jan 31, 2019 9:11 pm
No, this is a small antenna not even one meter in diameter.
Scheig
Post by zsolt on Thu Jan 31, 2019 8:33 pm
HI,
is the talking donne here about 20 meter loop antenna ? really 20m in diameter in vertical position ?
zsolt
Post by Admin on Wed Jan 30, 2019 8:37 pm
No problem.
I have often answered questions without first reading them properly. So easily done  Wink
if you want to build it for other bands then you can indeed scale it. If you "under-cook it" and find the natural resonance is, say, 14.9MHz, then you can thread a plastic tube between the turns to stagger them and get more space between them, horisontally. Very Happy
If you have any questions then do not hesitate to ask. You are always welcome  Smile
Best regards from harry - SM0VPO (and EA/SM0VPO)
Post by Scheig on Tue Jan 29, 2019 3:56 pm
Sorry, just answered my own question. Forgot about the geometry. The wires are actually about 2.8 CM apart.
Scheig
20M Loop Empty 20M Loop
Post by Scheig on Tue Jan 29, 2019 3:42 pm
I was very much interested in your design of your 20 m loop antenna. I want to build one myself although it needs to be a bit smaller and I'm going to build it for 15 m. The question I have, is if you found a self resonance with the wires spaced at 2.5 cm why did you then build it with the wires spaced at 4cm?
Scheig
