400 mw VHF amplifier
Re: 400 mw VHF amplifier
Hi John,
There is a lot of info on the pages. HHH was originally my lab-book with circuits and ideas. Instead of writing everything in a notebook, then losing the blooming book, I started HHH and put all my useful experiments and notes there.
The generic VHF PA pages was among the first to be recorded so I could refer to them myself
Another page that could be of interest is calculating the input and output matching circuits:
http://213.114.137.174/blocks/transistors_match_00.htm
http://213.114.137.174/tx/vhfpa-00.htm
Incidentally, HHH is located at www.sm0vpo.com or http://213.114.137.174/
Altervista is a mirror site that I can also easily modify, especially when I am not at home. www.sm0vpo.com is a RaspberryPi on my bedside table. All the 16,000 pdfs in the datasheet library are there.
Another advantage is that from home I can simply SSH to the machine to edit the pages in Linux, using GEDIT or VI. I can also FTP files to and from the machine and the changes take immediate effect.
Very best regards from Harry - EA/SM0VPO
Digging further today I found a link where Harry already addressed a linear VHF PA!
http://sm0vpo.altervista.org/tx/vhfpa-00.htm
Thanks Harry!
John
KC9OJV
Thanks Harry!
John
KC9OJV
KC9OJV- Posts : 3
Thanks for your comments. I think that if I end up using a push pull design I might as well take it to class AB but I'm going to try converting Harry's design to Class A first. I didn't know much about Class B and it's an interesting design so thanks for mentioning it!HRouse wrote:In Class C mode the amp is stable, but as you convert it to class A it becomes less stable,thermal runaway is the main cause. Class B would be a better option as it still has some bias, but room for thermal effects
John
KC9OJV
KC9OJV- Posts : 3
Linear Amp
HRouse- Guest
I'm hoping to be able to run Harry's 400mw VHF Class C as Class A with a fixed bias added. Looking at the example of Class A circuits it looks like I should be able to add bias resistors R1 and R2 (from the Class A example- not R1 and R2 on the 400 mw design) at the grounded side of the transformer T1 and add a capacitor C2 parallel to R2. I'm not sure how to calculate the proper values for these components and maybe it's not that simple?
Thanks for your help,
John
KC9OJV
John
KC9OJV
KC9OJV- Posts : 3
» 4W AF Amplifier
» 10W Linear RF Amplifier
» 800mW FM RF Amplifier
» 2m 1W 2N3904 Amplifier
» 4W AF Amplifier
