Some practical values for a half-wave dipole antenna
Re: Some practical values for a half-wave dipole antenna
Post by Admin on Sat May 25, 2013 8:42 am
You are most welcome any time but if you have any specific idea as to the antenna you want then please come back. Ivan i8s especially good at antennas and I have some experience, not to mention all the other people here who are keen to help you.
Nerja, Spain
Post by Dyon on Mon May 20, 2013 11:23 pm
Thank you all for the information.
Regards.
Dyon
Post by Admin on Fri May 17, 2013 3:37 pm
Post by DragonForce on Thu May 16, 2013 12:09 pm
Dyon wrote:Hi Ivan,
I do not have any particular frequency in mind.
All I want is a complete info about a working half-dipole antenna (center-fed). The frequency does not matter much for my present purpose but it must be that antenna's fundamental and higher harmonics. I am interested to make some calculations.
The radiation pattern should be -if at all possible- the pattern for free space (away from ground) for the fundamental and some higher harmonics. The pattern must be measured, not calculated.
I will appreciate any help.
Thanks, Ionel
But the length of a half wave dipole will depend upon the frequency you wish it to be resonant at - it's like asking "How long is a piece of string".
The approximate length of a halfwave dipole (in feet) can be found from 468/MHz. That gives you the total length - obviously divide by two and feed the antenna at the centre point (quarter lambda up, quarter lambda down, assuming a vertical antenna). Impedance at the quarter wave feed point is 75R I believe.
See here for precise information: https://en.wikipedia.org/wiki/Dipole_antenna
DragonForce
DragonForce
Post by Dyon on Thu May 16, 2013 11:26 am
Thanks, Ionel
Dyon
Post by Ivan on Wed May 15, 2013 2:08 pm
what band are you interested in ?
The voltage and current depend on the power in use (really much !! Laughing). They are also affected by the surroundings - height above ground, nearby metallic objects etc.
Measuring of the radiation pattern is out of possibilities of an average ham on longer than decimeter waves. Probably a copter would be required ...
Post by Dyon on Wed May 15, 2013 7:46 am
I would like to know the parameters of a real-life, working, tested, half-wavelength dipole antenna (center-fed).
I would appreciate if you could help me with information on:
- physical dimensions, length/diameter
- material used
- fundamental frequency (not theoretical, practical)
- amplitude of the voltage at the feeding point
- amplitude of the current
- measured radiation pattern
Many thanks, Ionel
Dyon
