WAV audio to EPROM Blower-by SM0VPO
WAV audio to EPROM Blower-by SM0VPO Empty Re: WAV audio to EPROM Blower-by SM0VPO
Post by Admin on Wed Aug 07, 2013 7:05 pm
Ruud wrote:
One trick I did do was to ... :-)
Are you serious? I think it is a rather unusual way to edit a binary file in MS-Paint!...
(Personally I use a hex-editor for that.)
Yes, I am absolutely serious. It takes but a few minutes. Although it is a "klick exercise" st do the final save, you get to edit complete columns in picture format. You can take 16-bit and make 8-bit, remove a stereo channel. It is perfect for swapping text round.
The final text cut from PDF to TXT generates a file that you only need to paste in the EPROM locations before each line and load directly into your EPROM burner.
Do not forget that you are not editing the binary itself but simply copying the blocks of bytes you want. You can cut/past blocks vertically or horisontally. Whats more you do not need to buy any software, s long as you have a WYSIWYG word processor.
Best regards from Harry
Post by Ruud on Sun Jul 28, 2013 9:03 pm
One trick I did do was to wind my screen res to max and do a BMP screen dump of a WAV file. In a picture editing program (eg. PAINT.EXE) you can delete alternate vertical rows and push the gaps together. Paste (import) the picture into MS-WORD, save as PDF and then you can cut'n-paste the text back into a TXT file from the PDF viewer :-)
Post by Ivan on Sat Jul 27, 2013 9:12 pm
good recording programs should give you selections between 8 and 16 bit precision, mono and stereo, and the sampling rate.
Post by Admin on Sat Jul 27, 2013 8:19 pm
Analogue1 wrote:Hi Ruud
Thanks for that. I will try that, but, as I said, I'm alittle rusty om digi stuff. Have u any circuit suggestions for these please
Regards
A
 To get 16-bit audio simple connect two EPROM control and address in parallel, but use the D0 to D7 as D0 to D15 (8+Cool using the resistive D to A converter.
In a different description, buikd a 8-bit as shown and "piggy-back" a second EPROM on the first after seperating the Data pins.
As regards the binary file, read it as 8-bit but there are 2x 8-bits to a 16-bit word. Then the next two 8-bit bytes are the left-hand channel.
Post by Ruud on Sun Jul 21, 2013 11:09 am
My advise: just start with the project!
There is really not very much that can go wrong.
Simply start with the 8 bit version as Harry described.
If it works, try to change the clock frequency and maybe the audio filter capacitor.
At the moment you have got more experience with the circuit, you may exchange the EPROM for a bigger type (longer play duration) or even change (or cascade) the counter to drive the extra bits for the EPROM inputs. Doing things = learning! (And fun!)
Start simple and build from that.
Post by Analogue1 on Sun Jul 21, 2013 10:40 am
Hi Ruud
Regards
A
Analogue1
Post by Ruud on Sun Jul 21, 2013 10:11 am
I once used the same principle, but with two EPROMS and two R-ladders.
Both EPROMS were driven from the same counter.
Also I used a 16-bit WAV file. One EPROM contained the 'high' bytes, the other EPROM the 'low' bytes. By adding the outputs of the R-networks in the correct ratio, I got a 16 bit resolution. (A better audio quality!)
Post by Admin on Sun Jul 21, 2013 9:56 am
I must add that it is always refreshing when others take my projects and expand on them. It would be nice of you could also post the results of your modifications.
A others pointed out, just extend the memory and increase the speed for a higher bit-rate. But without compression this will eat memory.
Post by Ivan on Wed Jul 10, 2013 8:42 am
Hi Paul,
it should be enough. Increasing the sample rate extends the bandwidth (eventual filtering should match the maximum AF), but shortens the play time. Extending the address counter and using a "longer" memory prolongs the play time.
Post by Ruud on Tue Jul 09, 2013 3:45 pm
I don't see a problem in changing the clock frequency.
As long as the audio file is 8 bits, it should work.
There is almost no filtering (only the 1 nF capacitor), but you could change the value of the capacitor.
WAV audio to EPROM Blower-by SM0VPO Empty WAV audio to EPROM Blower-by SM0VPO
Post by Analogue1 on Tue Jul 09, 2013 1:59 pm
Hi All
Just wondering if it was possible to expand this circuit  http://www.sm0vpo.com/eprom/wave_00.htm  to 1 second or 0.5 seconds and up the sample rate to 16-20K
I am an old analogue head, and would appreciate some input on this. I suppose just upping the clock/sample freq and changing the filter frequencies is not enough?
Cheers
Paul
Analogue1
