Push-Pull Voltage Regulator Amplifier transformer T2
Re: Push-Pull Voltage Regulator Amplifier transformer T2
Glenndk wrote:Admin wrote:Hi Russ,
You want to drive a 50 Ohm load, so T2 impedance ratio is 14:50, or about 1:4.
BR Harry - SM0VPO - EA/SM0VPO
Sholdn't it be sqrt(50/14) or about sqrt(4) ?
Hi Glen,
yes you are quite correct.
2+2 turns and 8 turns.
This is a 68-year old brain I am workin with ;-)
Hi Russ,
Sorry for the late response.
If I assume 100% output, the RF voltage is 8V at 600mA = 5 Watts
Impedance = 14 Ohms.
The actual number of turns is not so critical as there is a useable frequency range of about 30:1. Too many turns and the inter-turn capacitance is a problem (at 30MHz). Too few turns and the coil does not have enough indictance to have a high impedance at low frequencies.
Using a medium ferrite with two holes, use 2+2 turns for the primary and 16 turns for the secondary. This sould be perfect for about 3MHz to 30MHz. If you need lower frequencies (top band?), then use 4+4 and 32 turns, and let me know what time/date you are on the band.
Thanks Ivan,
I am seeking to get a rough estimate of the number of turns of wire to
start with for the primary of T2. Just a ballpark figure.
Best regards,
Russ
Best regards,
Russ
Russ666- Guest
Hi Russ,
"The circuit can be used for audio or radio frequencies." If you intend to use it for AF only, ferrite cores for AF with big mju are a good solution. The number of turns will decrease significantly.
I recommend you "the cheap ferrite rings from computer power units (about 2cm Dia.)" as mentioned in the 2,5 W version. One piece will be enough for less power.
Ivan- Posts : 788
The suggestions for T2 (audio) involve using a mains transformer.
My questions are:
Would it be practical to wind T2 on a ferrite core for audio frequencies, or would
that involve an excessive number of turns?
If not impracticable, what would be a reasonable number of turns to try with for the primary?
Best regards,
Russ
My questions are:
Best regards,
Russ
Russ666- Posts : 1
» PA transformer
» End fed wire antenna + coaxial transformer
» 4W AF Amplifier
» PA transformer
» 4W AF Amplifier
