MOD SWR to POWER METER QUESTIONS
+2
indrasung
6 posters
Re: MOD SWR to POWER METER QUESTIONS
sm0vpo wrote:
I have just searched my homepages for a broadband modification to a cheap VSWR meter as in this thread. I have already built the project, written the HTML files, but apparently forgotten to upload them. I will have a good look for them after the "Christian Festival of Spending" is over.
Best regards - Harry - sm0vpo
How about this - no SMD necessary:
W7EL, Feb, 1990 issue of QST magazine.
A simple and accurate QRP Directional Wattmeter.
Make a few small enhancements to the Bruene watmeter and diode detector, and you have a directional wattmeter that's simple, portable, and accurate from 10 watts down to 5 milliwatts!:
http://www.qsl.net/kl7jef/QRP%20Directional%20Wattmeter.pdf
backup:
https://web.archive.org/web/20170313085539/http://www.qsl.net/kl7jef/QRP%20Directional%20Wattmeter.pdf
A Bruene Bridge Directional Coupler with DC Output (V2):
https://electronicprojectsforfun.wordpress.com/rf-module-gallery/swr-bridges/a-bruene-bridge-directional-coupler-with-dc-output-v2/
backup:
https://web.archive.org/web/20200906013415/https://electronicprojectsforfun.wordpress.com/rf-module-gallery/swr-bridges/a-bruene-bridge-directional-coupler-with-dc-output-v2/
Transmission is fairly OK, only 0.5dB down from ca. 1MHz to 170MHz. The sweet spot is ca. 30MHz, with 0.25dB thru attenuation. Reflection also OK, better than 20dB up to 350MHz. Fair enough. This part is definitely usable up to the 2m band.
At the end of the day, we can state the following:
It works. Matched VSWR is accurate to 3% up to the 2m band.
February 4, 2015, More Notes on Directional Couplers for HF -- the Bruene Coupler, Part 1:
https://k6jca.blogspot.com/2015/02/more-notes-on-directional-couplers-for_4.html
backup:
https://web.archive.org/web/20240127135028/https://k6jca.blogspot.com/2015/02/more-notes-on-directional-couplers-for_4.html
Here's an interesting take on the Bruene Coupler, published by W7EL in the Feb, 1990 issue of QST magazine.
Per the article, this version has +/- 7% accuracy over the range of 1 to 432 MHz. Quite impressive!
The only negative that I can see with respect to the design is that you need to wind 3 transformers!
You could use more or less of the circuit from ( http://karinya.net/g3txq/swr_meter/schematic.jpg ), with the QRP Directional Wattmeter.
Harry, as for the metering circuit, have a look at this
https://karinya.net/g3txq/swr_meter/
https://karinya.net/g3txq/swr_meter/schematic.jpg
not only it's rather simple, but it offers very good precision, just check the AD8307 datasheet and you'll see it
Hi Harry,sm0vpo wrote:This is a really interesting thread. I have now got an idea:
I have always wanted a two-pointer VSWR meter, but the mechanics were always against me to make a reasonable job, but not now
I have a 3D printer, a computer and a scanner printer. I also have PhotoShop. All I need to do is to resize this picture to get the exact mounting positions and the scale for my VSWR meter. Then I can drill (or print) a plastic panel to suit the meter movements, and glue the image below on it.
It may be necessary to extend the meter pointers and add a bit of solder blob to the counter-balance so the pointers are not affected by gravity (that is at the little X at the hub of the meter movement). If the meter movements are cannibalised from a couple of cheap $5 analogue multimeters then you may not have to extend the pointers
or you can get one here (more sellers offer it for nearly the same price).
" One small comment, if the watt values here are to remain, then one can physically reverse the IN and OUT terminals to get a 300W or 60W range. "
But the red lines of equal SWR would be reversed in the 60W case.
Making a wideband direction divider is the most tough task when designing an all band HF SWR meter.
I am doing some basic experiments with the ESP32 MCU. It is amazing what this little beast can do! One ESP32, a cheap OLED display and good shielding could replace the two-needle meter, adding a WiFi connected web server. You could have the SWR meter directly at the antenna and read the values remotely on your smartphone.
The forward meter can be fitted with a shunt so that the same voltage divider can be used for the 300W forward and 60W reflected. Alternatively use PhotoShop to change the scale for other values.
I will shortly have a lot of time on my hands, even with a lady friend, so I may christen my retirement with this project before I continue with some older (unfinished) projects.
One small comment, if the watt values here are to remain, then one can physically reverse the IN and OUT terminals to get a 300W or 60W range. Use a transmission line transformer and it will not be frequency conscious.
PS - This is the VSWR meter that I "linearised":
MODIFY AN SWR METER TO READ RF POWER
thnaks for the fast reply on my question about the cross-needle meter.
Yup, you're right, the cross-needle meter is a system of two meters in one singel casing. Thus a total of 4 connections (twice '-' and twice '+').
But the difficult part for me is the switch in the schematic diagram.
In the diagram the switch is in the FWD position, thus showing the FWD power.
No problem so far.
If I use the switch I can see the SWR. Great.But I can't read to meters at the same time I think.
What I understand from the drawing is that only one meter at a time can be read.
That's why I like to use a cross-needle meter. To read two meters at once.
But then the switch must be removed.
Am I correct to say that to use two meters, I leave the switch in the FWD-position (or just make a shortcut at that point) and copnect the
REF-postion to the '-'of both meters (ground)?
10 minutes later....
Think I got a simple solution:
Remove the switch.
For the REF-part, connect the cathode of the left diode via the potentiometer to the '-'of the left meter (GROUND).
For the FWD-part, add R1, R2, R3, D1, C1 to the right side and connect the cathode of the right diode via de potentiometer to ground.
No problem so far.
Remove the switch.
Last edited by Alexander on Mon Dec 18, 2023 8:42 pm; edited 1 time in total (Reason for editing : New ideas)
Alexander- Posts : 1
Hi Alexander,
to be honest, I have never played with a cross-needle meter, so I may be absolutely wrong. I suppose it has two microammeter systems, each moving one needle. Each of the systems would be connected to one diode, so that one needle shows the FWD power and the other the REF one.
I had the same question as previous person (100W output).
But my new question is:
I like to change the SWR-PWR.GIF with one single cross-neelde meter in stead of two meters.
In that case I should remove the FWD-REV stwitch and connect the right hand diode to the SWR-meter,
but....where to connect the left hand diode?
Maybe someone can solve tjis 'problem'.
Alexander, PE1JUZ- Guest
the RF voltage on a matched 50 ohm line is slightly more than 70V at 100W. The toal power lost on R1 and R2 is therefore 2,5W, i.e. 1,25W each. Use 3W or 5W low inductance resistors (avoid wirewound types ). The power loss on R3 is negligible. The value of R3 depends on the internal resistance of the microammeter used.
» AD8307 power meter
» Vu meter, RF probe, GDO queries
» 250mW 40 Meter AM Transmitter
» Field strength meter
» grid dip meter frequency pulling
