Looking for suggestions for tube rf-chokes
Re: Looking for suggestions for tube rf-chokes
One thing I used to do for "air cored" chokes for tubes was to cut a rubber grommet in 1/2 down the middle, the glue each 1/2 to the ends of a 1/2-Watt or 1-Watt resistor. You can use an electric screwdriver or drill to wind on the firmer that was made.
The resistor should be 1-Megohms or more. The length of wire should be like 1/4-wavelength or so, which means you can get really thin magnet wire from high-voltage (24V) miniature relays.
It was a simple method, and quick, too :-)
Thanks
Yes, thanks, finally I've found the time to fully read it. Learned a lot!
Many thanks again
Giuseppe
Many thanks again
Giuseppe
Giuseppe Stancanelli- Posts : 3
Thanks, but 3d printing is an option, not mandatory
I'm only looking for a choke solution that works. in order to not add uncertainity in my first attempts in receiver diy building
... and I don't have any of the kind of chokes you wrote :-)
Giuseppe
Giuseppe
Hi Giuseppe,
which choke do you have in mind? The anode one, the filament filter or something else?
Generally, using a 3D printer to make choke formers may cause problems with deformation of the thermoplastic material, if the winding becomes hot. Ceramics or teflon are preferred.
Hi, I'm a new user of the forum but a long-time reader of your site, from around years 2004-2005.
I thank you for all the work and passion you put in it.
I'm studying for my Ham license, I'm from Italy, and I do some SWL with a kenwood ts130.
I have some experience in electronics, molstly analog stuff, and now I want to try some tube receiver/trasmitter project.
As many in EU, currently I'm stuck at home, but I think I have all the required components, bar the rf-chokes
If I try googling for rf-choke or similar terms, I only find documents on the antenna chokes
So, finally, my question is:
Do you have any suggestion for home building, as you did for replacing denco coils?
I own a 3d printer, and I can model and try coil formers
Thanks in advance
Giuseppe
Thanks in advance
Giuseppe
» [Contact] 2-tube TX
» Testing tetrode tube
» Harry's copper tube reonator
