Testing tetrode tube
Re: Testing tetrode tube
Hi Gertie,
I think you will find that the object is to see if the tube can still carry current that the cathode has not been stripped (causing low emission).
As Ivan wrote, you should check the continuity to be sure that no electrodes are shorted. Other than this the major faults with power tubes is low emission, which is what this test checks.
Current
Thats my question : what/how does the current flow into a tetrode if you test a tube at that way.
If you know that for example a 4CX1500B has about 1 watt of dissipation on the control grid.
Gertje- Posts : 2
it probably is O.K. I saw a pentode (RV12P2000) with grids connected to the anode used as a rectifier diode in a schematic from the 50s. The tube should be tested for shorts first. The currents seem to distribute properly if there are no shorts nor disconnections inside.
Doesn't feel right to me, because you have no idea how the currents (grids and plate) are divided.
https://www.youtube.com/watch?v=aHoiPuESpe4
I found this video how someone test a tetrode 4CX1500B tube.
Can it be done like that ?
Grid + screen + anode togheter and heating up.
What about the current in the grid and screen ?
Thanks
Thanks
Gertje- Posts : 2
» RF generator circuit for designing/testing circuits for HAM radio
» [Contact] 2-tube TX
» Looking for suggestions for tube rf-chokes
» Harry's copper tube reonator
