4W 96MHz Amplifier (2N7000/BS170) !!
Re: 4W 96MHz Amplifier (2N7000/BS170) !!
yes, it is much better, although the sides still disappear in the shadow.
New imported gif image posted Ivan.
Please export the schematics to a graphic format directly. The readability of photos of a monitor is quite bad.
Thanks. BR from Ivan OK1SIP
12V and R10 = 2.2ohm, Po is 3.4W , each mosfet burning 250mW as heat. Pin is 96MHz at 360mW
A solid 3W at 12V on 96MHz! BS170 should work as expected. LtSpice is awesome.
Load = 75ohm
Load = 75ohm
Drive level is 360mW @ 96MHz.
0.4A final stage current @ 19.2V or all three mosfets combined.
DC input = 5.4W
RF output = 4.5W into 75ohm dummy load after LPF. Half wave dipole antenna is recommended.
DC input = 5.4W
dare4444 likes this post
» GIF image for Ivan (96MHz 4W BS170)
» BS170 + IN4148 Mixer
» 2n7000 102MHz amp
» 100% modulator 2n2222 +2n7000 SW AM TX
» 2n7000 102MHz amp
