Quick "car" antenna stand
Re: Quick "car" antenna stand
Admin wrote:Hi Andrew,
I have seen something similar in a previous post, but it was all metal tubes.
It really is a good idea, and this particular version could be insulated from the ground, with a little thought.
At the moment I am waiting for better weather so that I can have a good trial with my "Gay-Pride" telescopic antenna. It is all tuned up and ready to go.
I have also fixed the magnet problem - a small magnet at each corner of the aluminium plate. Perfect for positioning, and the magnets are padded so they don't scratch the roof of the car.
Then I put a 25kg neodymium magnet in the middle of the aluminium plate. That sits like a limpet.
To remove the 25kg force magnet is no problem. It is the aluminium plate that gets scratched, not the car
Nice to hear your magnetic antenna project is proceeding, regarding the "drive on stand" I was thinking to this antenna
http://sm0vpo.altervista.org/antennas/small-hfant-mobile2.jpg
now, adding some kind of support to the bottom of the box would allow to quickly deploy that antenna, even if there's wind, to use the car as the "counterpoise" and ... to operate from the comfort of the car even in bad weather
Thank you for sharing the ideas, I really appreciate it.
This one is definitely for Harry, let me start by showing the antenna stand
https://wb3gck.com/2017/01/15/drive-on-portable-antenna-support/
now, imagine modifying the above so that the "wheel stand" (wooden tablet) is someway integrated into the wooden box containing the antenna loading coil; using such a support it should be quick and easy to deploy the vertical, just a matter of driving over the "support" with a wheel and extend the antenna, plus the car may be used as a "counterpoise" just by connecting a cable (like a battery one) between the antenna "ground" and the car chassis !
What do you think ?
What do you think ?
