New project "500mW Retro AF Amplifier + experiments"
Re: New project "500mW Retro AF Amplifier + experiments"
Hi Harry,Admin wrote:... they are 1:1 ...
the link should point to 1300:8 ohm transformers. I probably made a mistake. The same supplier has also 600:600 ohm ones, which you probably have in mind. I ordered both types, I'll see what they are worth.
VBR Ivan
These transformers you quoted would probably work really well. I see that they are 1:1, so the two windings could be connected in series to form a 1:2 auto-transformer.
Thank you very much for the input. Really appreciated.
Most of the tasks can be accomplished also by a simple A-class amplifier with an output transformer. Suitable transformers are e.g. these ones. They do not have the center tap of the primary, so they do not suit into a B-class amplifier.
Ivan wrote:Hi, the "HX108-2 AM Radio Kit" from AliExpress is a good source of rare parts. It contains two AF transformers, a 0,5W loudspeaker and a suitable PCB. Besides that you get a variable capacitor, three canned coils (oscillator and 2 IF 465 KHz), 7 transistors, passive components and a box. The price is reasonable. Several sellers offer it.
HX-108-2, I will have a look at that. I have seen loads of kits (I was in a meeting when I wrote that / the boss was calling !! That's why the answer was so short).
I saw on AliExpress and BangGood that there are several AM radio kits. I saw reasonable prices in the region of $7 upwards. All the brand-new components not soldered. There are also AM radios for about $2.50 that you have to de-solder. I think it is strange that a bag of bits can cost more than the same components already assembled.
In the last two months I see that the new transformer sets have disappeared and IF transformers have also become difficult to find. I have a good stock of those, enough to last me my lifetime The only things I have NOT been able to find are the red oscillator coils. I have a few radios I can cannibalise if I ever get the need for a MW oscillator coil, but I also have the coil-winding data.
Thank you very much for the response Ivan. Really appreciated, as always.
Ivan wrote:Hi Harry, Radio NIVEA is an easy Czech QRP CW TRX, designed to start interest in electronics, homebrewing and hamradio. Maybe it will interest you?Admin wrote:If you have any ideas for children's projects then please give me the suggestion and I will see what I can do. Any suggestions have got to be fun, cheap(ish) and nothing that can entice the in-built smoke in semiconductors to escape.
Hello Ivan, I will take a look at that. At the moment everything is of interest, but I have five ideas on the desktop.
Thank you very much, I will check it out now :-)
Very best regards - Harry
Ruud wrote:"any potentiometer of about 4.7Ω through to 25KΩ"
I suppose that should be "4.7 KΩ through to 25KΩ"
Of course 4.7Ω will work(!), but I doubt if potentiometers with such a low value exist!
Also the input impedance would be so low, that the input could only be driven from a loudspeaker output.
(But that would eliminate the need for an amplifier... )
Oops!! Sorry Ruud. This is exactly the reason I have previously asked you or Ivan to review a project before publishing. Ob this occasion I thought it was so simple a spelllchack would be ok
Thank you for the correction and I shall update it. It is too late, but probably in the morning.
Thank you very much for your comment. I really appreciate it.
Have nice evening, at least that bit remaining. Harry - SM0VPO
Hello John,
Thank you for the reply. I just love the simplicity myself.
As regards using a mains transformer, that is easy. Here is a miniature 1W transformer. Use a 12-0-12v - 230V transformer. Costs about US$6 for one, unless you choose China, then the price drops.
The two windings are modular so you can remove the 230v winding and rewind it for 6v (8-Ohms), then reassemble. With this design there is no standing DC to saturate the core, so the calculations without standing DC work: the small transistor bias current is equal and opposite in each half of the transformer. You just need to make a test winding to find the turns/volt. Also the PCB will not work, but there is not much on it to start with.
Thank you for your comments. Really appreciated.
Great project. The transformers may be a little old fashioned now but no matching NPN/PNP devices, no bootstrapping and no need to look for that elusive VCC/2 at the output, or one output transistor running hotter than the other. I wonder if a small cheap mains transformer could be rewound for the Output transformer? I saw an article somewhere for an AM modulator using a ferrite core trafo like the ones used in SMPSUs....
I did some experimenting earlier this year with low power af amplifiers and found the sziklai pair configuration worked best for me, but I love the simplicity of the transformer coupled amplifier.
John_1981- Posts : 32
Hello people,
I think that this is a really interesting project that dates back to a project I built back in 1961 or 1962. It was one of the first multi-transistor projects I ever built. An audio amplifier using inter-stage and output transformers. Before you say "poooo-old-hat, you are showing your age, Harry", yes I am showing my age.
A modern complementary amplifier does not need transformers, but there are a couple of things you can do with a transformer amplifier that is a lot more difficult to do with a more modern design.
For example, light-beam telephone using a torch (pocket lamp) lamp, or using a LASER, AM transmitter modulator, long-distance microphone, and many others. If, like me, you can be a little childish and like to prank-people then I have included something for you. I manage to make a mother of two quite hysterical, but you can read about it in the article.
I started this project about 9 months ago but it sat on the back shelf waiting for "a rainy day". But I think that -9°C and snow can count as a rainy day. Took me only a few lunch-breaks to finish it.
If you have any other ideas, corrections or suggestions, then please drop me a line, preferably via this forum.
There is another project I started about a year ago after I got a suggestion for communication/technical projects for children.
I immediately came up with a couple of ideas and I will work on one of them in my lunch-breaks, as long this snow lasts. If you have any ideas for children's projects then please give me the suggestion and I will see what I can do.
Any suggestions have got to be fun, cheap(ish) and nothing that can entice the in-built smoke in semiconductors to escape. I don't want to be accused of coercing young people to exterminate semiconductors. I will also entertain anything that is remote to radio and electronics, but it must be fun and hopefully, educational.
» New project on www.sm0vpo.com - Retro audio amplifier
» Project update - AF Generator (retro design)
» Current project - Guitar / stereo amplifier
» Tunnel diode "Interesting" (i.e. useless) experiments
