2m 1W 2N3904 Amplifier
Re: 2m 1W 2N3904 Amplifier
1W out 40mW in at 145MHz and 6V supply. Dissipation per 2n3904 Final = 150mW at 6V. Final current is 250ma for both transistors. As an example let's take 350mW dissipation temperature = 95C (Ambient temp 25C + heat generated) which is still less than 150C for silicon. It should work fine, I suggest glueing them to the board for heat dissipation. It works great when construction is ugly bug:)
Del
» Parallel 2n3904 transistors as VHF PA
» 2n3904/PN2222A 150mW Stable FM Transmitter
» 4W AF Amplifier
» 400 mw VHF amplifier
» 4W AF Amplifier
