RF speech processor
Re: RF speech processor
Glenndk wrote:Hi Andrew
You could camouflage the circuit as a tube - important: Bandpass filter your audio before rf-speech processing:
http://earf.co.uk/rfprocessor.JPG
http://earf.co.uk/weaver.html
Well, camouflaging it would be cheating ... but thanks for the idea and the pointers, at any rate the processor is now built... a solid state one
Hi Andrew
Ivan wrote:Hi Andrew,
a double balanced mixer based on triodes or pentodes is fairly complicated and two mixers are required here. This may be the reason why nobody has designed such circuit.
I am thinking about a device consisting of:
- a ring modulator with 4 vacuum or germanium diodes;
- a triode or pentode (ECO) RF oscillator;
- one stage tube amplifier, perhaps not necessary;
- a neon lamp or two zener diodes as a clipper;
- a crystal filter;
- ring mixer with 4 diodes as a demodulator;
- an output tube AF stage.
It should be reasonable especially if semiconductor diodes were used in both mixers.
Just an idea.
Thank you, Ivan, I think I finally convinced him to go solid state the circuit chosen, at end, was the PA0FRI one
thank you again !
- a crystal filter;
Just an idea.
- a crystal filter;
Just an idea.
RF speech processor
Hi folks, hope you all will have a nice 2023
Getting to the topic, let me start from this
https://pa0fri.home.xs4all.nl/Diversen/DSBclipper/dsb-clipper.eng.htm
now, the above is a "classic" RF speech processor, where the AF in amplified, converted to RF, clipped (in this case, or limited in other circuits), converted back to AF and then used to fed a TX audio (mic) input
Now, the above circuit is ok, but let's say one owns a boatanchor, say a Collins KWM, and would like to add a TUBE based processor; I searched the intertubes a lot, but it sounds like all those processors are "solid state"; any pointer to a vacuum tube circuit ?
