New project on www.sm0vpo.com - For IVAN
New project on Harry's Homebrew Homepages.
sm0vpo wrote:Hi Ivan,
Thank you very much. I will add the links and upload the files, hopefully tomorrow.
I was interested to see the 555 timer link.That looks quite simple. It would be interesting to see how accurate it is with the pulse timing, but it is really simple.
Thank you once again.
BR Harry - sm0vpo
If you look at the www.sm0vpo.com homepages you will see there is another new project. It is this "Servo tester". I have included the PCB foil, circuit diagram and everything you need to complete the project.
The unit can be used to simply test RC servos, but it can also drive a servo to remotely tune an antenna at the bottom of the garden. You can even stuff the single-channel pulse into a transmitter and have a 1-Channel RC unit. Mine worked with a 433MHz TX and RX module, as listed in the article.
A big thank you to Ivan for reviewing the project.
Re: New project on www.sm0vpo.com - For IVAN
BR Harry - sm0vpo
BR Harry - sm0vpo
the article is IMHO O.K. and you can publish it.
I played with a servo a few years ago, but I used other types of controllers:
1 - with 555, similar to the controller from this page.
2 - with PICAXE 8. I used PICAXE quite much, the program for servo control in Basic was short and simple.
Both approaches worked on the first attempt. The astable multivibrator will surely perform equally well.
https://www.sm0vpo.com/use/rc-servo-tester-1.htm
Hello Ivan,
Can youi please do me a vafour and have a quick look at this new project before i point all the links to it?
There is not too much to say about it since the text just about says it all. Basicalli I am plodding along with my RC boat, but need to design a high-voltage speed controller, and for tht I need to synthesise the signal from an RC receiver. Because it has an analogue input, it is out of my comfort area for PIC programming. Tried AI and gave up on them, they are not so I
I hope to update the links to the project as soon as you have given any comments.
If anyone else has any comments then they will be gratefully received.
Hello Ivan,
» Can Ivan and Glen please take a look at this page for me? (new project)
» Yet another new project on www.sm0vpo.com
» New project on www.sm0vpo.com - Basic HF / VHF filters
» New project on www.sm0vpo.com - 3D Printed Portable HF Antenna
